Share
 NEW LIFEBOAT BUILDS......on the way.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Empty
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyMon Oct 07, 2019 8:21 pm
today, I continued to ready the static boat for laying on the end boxes...…..
I sanded the wooded support beading and glued the stern box in place using 30 minute epoxy.
the bow section was readied in the same way, sanding a chamfer onto the wooden beading, but before the top was glued in place, I made the covers for the bulkhead, using 1.0 mm mahogany faced ply wood onto which I drew the "boarding" and two locker doors onto the timber to simulate the locker boxes set into the fo'csle for rope storage.
once this was done, I glued the top on and held with masking tape till set.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3149
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3150
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3151
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3152
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3153
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3154
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3155
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyMon Oct 07, 2019 10:02 pm
well, that was easy.....
the end boxes on the static boat glued on easily and just need a little filling on the joints between hull and boxes. I just hope the ones on the self righting boat go as easily as they have been raised by about an inch or so...……….
but all that will have top wait until Wednesday, as got some phone calls to make tomorrow, plus empty my daughters car of all things in there as it is going for sale as she can't have it at university for the first year............and god knows what I'm going to find in it...…….
if however its raining, I don't fancy working in the rain and may be back to it by afternoon.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3157
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3156
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3158
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3159
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3160
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyTue Oct 08, 2019 10:23 pm
the static boat with the low end boxes has come out well now that the tops have been glued on...……...not so much filler needed on these end boxes, and this will be added tomorrow.
the motor sailor though, was different...…….
the uprights needed more packing than I first thought, but the stern end box needed more.
also I needed to fix into the stern, the rudder servo.
I found a mounting box for the servo, and added some packing to the base of the box to raise the servo arm to the height of the rudder linkage bar that I have already set into the stern port side.
the servo box was then glued into the base plate in the stern, already added at the start of the build.
then two support beams were added port and starboard of the servo to support the surrounds to an access hatch for the servo, which will be cut and fitted later.
the end box top was then glued on to the stern, using 2 part epoxy for grp to wooden edges, and aliphatic resin wood to wood.
it has now been left overnight before getting Joan Collins foundation out [ polyester filler] IN LARGE AMOUNTS...…. and filling the gaps on both boats, both ends, lol..
might take the new tin I've bought, lol.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3161
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3163
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3162
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3164
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3165
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3166
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3167
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3168
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3169
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyWed Oct 09, 2019 4:50 pm
today has been spent filling the gap between the sub deck and the bulwarks, filling the end boxes of both boats,
and then readying the insides of the bulwarks with an overlay of 1.5mm ply that has been marked in pencil with diagonal plank lines, that simulate the inside layer of planking of all the old double diagonal planked lifeboats, up until the Corten steel hulls of the Solent class lifeboats.
these sheets of marked ply will be stained with mahogany varnish this evening ready for fitting sometime tomorrow
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3170
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3171
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3172
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3174
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3173
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3211
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3212
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3213
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3215
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3214
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3216
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyWed Oct 09, 2019 8:23 pm
and yet another cock up...……..small one but still a cock up...…..
I bought some Colron a while ago for some staining on the Calmac ferry I built 2 - 3 years ago, and have not used it since. my original can which I had had for "years" was a lovely watery consistency which went on with a rag and spread nicely.....
I took this can, gave it a quick shake and applied to a rag, and proceeded to wipe over the "planked" pieces of ply.........it went on like custard, didn't spread at all easily, and obliterated the lined planking that I drew this afternoon...….so I have had to go over all planking lines with a black fine line draughtsman's pen, that I have in my collection...…..
I'll try watering the dye down tomorrow, but workshop is now closed and locked up for the night. if not i'll go and buy a small put of dye/varnish from the local DIY store.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3217
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyThu Oct 10, 2019 10:48 pm
this afternoon I put on the port side inner simulated diagonal planking .
to mate the planking up at the top which is seen above the side benches, the planking at the bottom of the bulwarks sometimes doesn't line up...…...but this is hidden by both the benches and the self floating buoyancy boxes, which will be made from white plasticard at a later date.
to trim the side "walling" I used my old method.....cut the end off a sharpened pencil, flatten one of the hexagonal sides to leave the pencil tip about a millimetre above the flat surface and using the deck as the surface template run the pencil along the piece of printed ply....sand off the edge to the pencil line which is parallel to the deck, and if need be repeat the process until you have one continuous lie along the plate....and sand down to get an exact copy of the decks sheer......
repeat with the next plate until all bulwarks are covered...….simples. I glued the plates to the bulwarks using 2 part 30 minute setting epoxy.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3219
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3218
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3220
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3222
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3221
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3223
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptySun Oct 13, 2019 10:00 pm
the plank simulated facings have been added to all end boxes now, and the upper capping to the bulwarks have been added to the motor sailor...……..
the static boat will have her cappings added tomorrow.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3228
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3229
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3227
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3226
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3225
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3230
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3232
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyMon Oct 14, 2019 10:25 pm
one set of bulwark cappings now glued on, and the other boat's cappings have been glued and clamped up.....
will take the clamps off tomorrow.
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3236
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3234
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3235
NEW LIFEBOAT BUILDS......on the way. - Page 2 Img_3237
PostSubject: Re: NEW LIFEBOAT BUILDS......on the way.   NEW LIFEBOAT BUILDS......on the way. - Page 2 EmptyYesterday at 5:50 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
TheRcModelBoatForum.com :: Modelling Categories :: Lifeboats-
