| Chinese Mini Tug | |
| Subject: Re: Chinese Mini Tug Fri Feb 15, 2019 12:36 pm | |
| This figure looks about the right size. unfortunately the pose is wrong, and I can't remember what scale he is supposed to be. Two his size with hands free would be good. The problem with these figures is that you get a random selection of poses. More paint has been applied - I am sticking with more conventional tug colour schemes I also made a searchlight and a radar scanner. I just need to make navigation lights and an aerial. I will not be fitting a mast. I have a couple of bollards for the rear deck. I can't do any more to the cabin until I get the wheel I ordered from BattlecraftsCMB, but I can give the deck another coat of paint, and finish off the capping at the stern. Barrie | |
| Subject: Re: Chinese Mini Tug Sat Feb 16, 2019 12:44 pm | |
| I gave the black a second coat after re-making the capping at the stern. Some other items were painted. I also tried my hand at sculpture I sawed off the right arm of one of my figures and have tried to create a new arm that will allow him to steer the tug. Apart from giving the deck another coat of paint, and finishing my reshaped man, I am now stuck waiting for the wheel to arrive. This needs fitting before I install the windows and roof. Barrie | |
| Subject: Re: Chinese Mini Tug Sat Feb 16, 2019 3:49 pm | |
| Subject: Re: Chinese Mini Tug Sun Feb 17, 2019 11:52 am | |
| Painting now completed on the hull. The Captain is almost ready to take command. Just need a steering wheel so I can complete the cabin. I think I have all the fittings ready to go. Barrie | |
| Subject: Re: Chinese Mini Tug Sun Feb 17, 2019 12:24 pm | |
| Subject: Re: Chinese Mini Tug Mon Feb 18, 2019 11:22 am | |
| Still waiting for my wheel I gave the lower hull and the deck a coat of matt varnish, after sticking the fittings on the deck. I have added a foam strip round the hull at deck level and will not be using the tyres that ere included in the kit. I have mounted the fittings on the cabin roof, although the roof is not fixed. Barrie | |
| Subject: Re: Chinese Mini Tug Wed Feb 20, 2019 4:05 pm | |
| Subject: Re: Chinese Mini Tug Wed Feb 20, 2019 9:44 pm | |
| are you pleased with it Barrie......I certainly would be...…...I think its a little cracker. TBH. |
| Subject: Re: Chinese Mini Tug Thu Feb 21, 2019 7:17 am | |
| Yes Neil - very pleased. For less than £50 including the extra bits I had to buy I think it was a good decision. And wait until you see my next project - that cost even less Barrie
| Subject: Re: Chinese Mini Tug Thu Feb 21, 2019 8:17 am | |
| Subject: Re: Chinese Mini Tug Fri Feb 22, 2019 2:06 pm | |
| OK Neil, just for you a little taster. This cost me £8.71 from China. It is not intended as a working model! Length of hull is approx 9.5 inches. so far I have dry fitted the bulkheads to the keel and then dropped on the deck. Everything beautifully laser cut and etched. The planking is laser cut from ply. It all fits! Build log when I start building properly. Barrie | |
| Subject: Re: Chinese Mini Tug Fri Feb 22, 2019 4:01 pm | |
| hi barrie, you said my build looked big, that looks smallllllllllllllllll ish david | |
| Subject: Re: Chinese Mini Tug Fri Feb 22, 2019 4:20 pm | |
| Subject: Re: Chinese Mini Tug Fri Feb 22, 2019 11:03 pm | |
| its a little cracker, barrie…………..hope you do get to sail it...……...nothing worse than a virgin boat. |
| Subject: Re: Chinese Mini Tug Sat Feb 23, 2019 6:50 am | |
| I will give it a go today. Part of the problem is the very limited access. I probably should have tried it before I added the deck Barrie | |
| Subject: Re: Chinese Mini Tug Sat Feb 23, 2019 12:32 pm | |
| Well - I managed to get just over half a kilo of lead into the hull. This brought it down quite a bit although not to the water line. I will have to wait and see how it performs when i get a chance to sail it.
| Subject: Re: Chinese Mini Tug Sun Feb 24, 2019 2:56 am | |
| Can you put a false keel under it with the lead attached Barrie? |
| Subject: Re: Chinese Mini Tug Sun Feb 24, 2019 7:02 am | |
| I could try Damien, but I think this is OK for the amount it will probably get sailed.
| Subject: Re: Chinese Mini Tug Sun Feb 24, 2019 8:16 am | |
| Subject: Re: Chinese Mini Tug Sun Jul 21, 2019 2:08 pm | |
| Finally got it in the water! It sails very well and looks pretty good. There is a problem with the rudder alignment, but otherwise I'm very pleased. Barrie | |
| Subject: Re: Chinese Mini Tug | |
