Share
 C200 centricast machine,melting pot,7" plate £825
Vicky
C200 centricast machine,melting pot,7" plate £825 Empty
PostSubject: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptyWed Sep 11, 2019 9:08 am
£825 for the C200 Centrifugal casting and mould-making machine (Centricast ©) from Alex Tiranti of Theale, Berks. and the melting pot by Seba Developments of West Yorkshire. Both well used and in working order. Includes comprehensive instruction manual (ISBN 0 85458 750 0) together with the necessary tools, mould plates, rings and formers for creating heat-proof two-part Room Temperature Vulcanising (RTV) silicone rubber moulds. The complete set up is illustrated (main photo) with the casting machine on the left with the lid open. For safety, the power is cut off if the lid is raised while casting hot metal.
Details: Model No. C 200, Serial T0204. Power: 240volts, from a normal 3-pin plug. Red button is the power-on light, rocker control is On/Off. The speed control is calibrated from 0 to 10. I used a modified box spanner to tighten the substitute nuts down onto the top plate when casting hot metal. In front is a flat scoop to pick up any off casts from inside the box.
On the right is the melting pot by Seba Developments, type TE5, serial 164, 240v. 750w. supplied by a normal 3-pin plug. The heat is controlled by a round dial, see fig 3, 0 to 400 deg C. It has a safety cut-out in case of over heating. The graphite dust (round tin) is half full. Shovel and ladel included and half a pack of lead free alloy metal.
The machine has been really well looked after over the years and in such good condition.
Will arrange delivery for £25
See photos below
Vicky
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptyWed Sep 11, 2019 9:09 am
C200 centricast machine,melting pot,7" plate £825 Screen22
C200 centricast machine,melting pot,7" plate £825 Screen24
C200 centricast machine,melting pot,7" plate £825 Screen23
Vicky
C200 centricast machine,melting pot,7" plate £825 Screen27
C200 centricast machine,melting pot,7" plate £825 Screen25
C200 centricast machine,melting pot,7" plate £825 Screen26
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptyWed Sep 11, 2019 11:12 pm
I can say to anyone who is interested in this and is a keen scratch builder that these machines are ABSOLUTELY BRILLIANT...…...I owned a full set up for 25 years and used it to cast both white metal and resin fittings for my lifeboats...……….they are unbustable and can recommend this set up which is for sale as a good snip of a buy...…...
my set up was similar except I had both the 6" and 10" rings and plates, and new worth over £2400...…...
so, if you want to get into centrifugal casting...….this set is a snip at £850.
and back up from Tiranti in Reading is excellent.
Vicky
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptyThu Sep 12, 2019 7:03 am
Thanks so much for that! They are amazing machines and don't come up for sale second hand very often. Im Sad to have to sell it but I'm expecting twins in February and won't have a use for it, hence why I need to sell it.
I would like to sell it asap if anyone is interested.
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptyThu Sep 12, 2019 11:06 pm
if you contact tiranti's they do keep a list of people  who want to sell second hand equipment.
they put a couple of guys on to mine which I sold reasonably easily.
Vicky
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptyFri Sep 13, 2019 6:59 am
Thanks. I have been in touch with tirantis but they said eBay was my best bet? Do you know who you spoke to? Thanks for your advice by the way!
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptySat Sep 14, 2019 3:27 pm
hi Vicky.....the guy I spoke too and cannot remember his name was in the technical department.
this was at the Theale branch near Reading...…...but looking at their locations they have moved to Thatcham in Berkshire...…….but it was definitely the London branch. I think the chap has gone elsewhere, but I would ask the technical department for their help.
Vicky
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptySat Sep 14, 2019 6:38 pm
Thank you!
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptySat Sep 14, 2019 7:12 pm
no problem...…….here to help if we can.
PostSubject: Re: C200 centricast machine,melting pot,7" plate £825   C200 centricast machine,melting pot,7" plate £825 EmptySat Sep 14, 2019 7:18 pm
just had a look at my own add regarding my sale, and the guy's name was/is Doug.
I know little more.
https://www.thercmodelboatforum.com/t1615-centricast-centrifgal-caster
TheRcModelBoatForum.com :: Traders & Sales :: Member's Sales-
