 Light Pad.
Light Pad. Empty
PostSubject: Light Pad.   Light Pad. EmptyThu Sep 15, 2016 6:22 am
Many years ago I made my wife a light box for use while doing art rather cumbersome with a 60 watt globe inside it was dumped when we moved house long ago. Since then I've used card and carbon paper to copy bulkheads, deck and cabin shapes.
While browsing ebay  I found this LED light pad A3 size with 3 light settings.
 http://www.ebay.com.au/itm/311604828200?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Light Pad. DSCF4276_zpscuueqrz9
Material Acrylic (organic glass)
Outside dimension 47 x 37cm
Perspective dimension 43 x 33cm
DC 12v 1amp plug pack supplied
Rated power 9W
Mine arrived today comes with Au 240v plug pack as I purchased in Aust.
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptyFri Sep 16, 2016 9:00 am
Looks interesting Damien, I will take a look, thanks.
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptyFri Sep 16, 2016 11:20 am
How do you actually use it Damien, is it used as you would with tracing/greaseproof paper with the item to be traced under the light pad ?
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptyFri Sep 16, 2016 12:06 pm
Yes Paul
Power up place plan over lit pad and tracing paper or I use 120gsm art paper on top over the pad and select light density to give best resolution to copy the parts you want.
This quick Pic of Josie plan without straightening the creases out with said 120gsm paper over it & No 2 light setting easily good enough to copy what you need.
Light Pad. DSCF4280_zpsby0ixa6d
Damien.
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptySat Sep 17, 2016 8:08 am
Thanks Damien, it certainly looks clearer than using what I used last time, I think it was bought as tracing paper.
Looks like Santa might need a hint in the right direction........... 2thumbsup
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptySat Sep 17, 2016 9:25 am
I bought mine with my fathers day gift.
inertia
inertia
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptySat Sep 17, 2016 10:20 am
http://www.ebay.co.uk/itm/A2-A3-A4-LED-Copy-Board-Scale-Drawing-Tracing-Thin-Light-Box-Board-Craft-BBS-/221486215507
UK supplier (allegedly?) with free delivery to UK; several different sizes and types available. Am now desperately trying to justify buying one of these for myself!
Dave M
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptySat Sep 17, 2016 10:46 am
Thanks for the link Dave.  2thumbsup 2thumbsup 2thumbsup 2thumbsup
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptySat Sep 17, 2016 11:03 am
Hi chaps,
      this link gives so many various types, which one is best for our application ?
Light Pad. Empty
PostSubject: Re: Light Pad.   Light Pad. EmptySat Sep 17, 2016 11:08 am
The A3 power D is identical to mine the icon in top left is the touch light switch brightness selector.
And the power plugs in just below that icon.
Light Pad. Empty
Light Pad.
» Making a 12v masthead light
» Changing a light bulb
