 Mantis build
Mantis build Empty
PostSubject: Mantis build   Mantis build EmptyWed Mar 21, 2012 7:54 pm
So here is the build of the Mantis tunnel catamaran, drawn by Glynn Guest, a free plan in MB Nov 1992.
I was inspired by my new found friend (Pirana) from Liverpool Model Boat Club.
I could really do with building it out of rubber as I am not very good at steering anything that goes faster than 5 mph, but as the plan says 5mm balsa for the main frame and 3mm balsa for skinning the hull, that is what I will use.
The only deviation from the plan is a thin piece of aluminium on the inside of the transom, skinning the underside of the tub with thin ply and a thin skin of ply on the outside of the transom.
Mantis build Dscf3563
Mantis build Dscf3565
Mantis build Dscf3564
Heyperman likes this post
Mantis build Empty
PostSubject: Re: Mantis build   Mantis build EmptyWed Mar 21, 2012 7:59 pm
Mantis build Dscf3566
Mantis build Dscf3567
Mantis build Dscf3568
Mantis build Empty
PostSubject: Re: Mantis build   Mantis build EmptyThu Mar 22, 2012 7:48 pm
Thin ply skin been glued to the bottom of the tub and 3mm balsa glued to hull sides
Mantis build Dscf3569
Mantis build Dscf3570
Mantis build Dscf3571
Mantis build Empty
PostSubject: Re: Mantis build   Mantis build EmptySun Mar 25, 2012 9:35 pm
Sanded to the right profile and the bottom skins glued on.
Mantis build Dscf3572
Mantis build Dscf3573
Mantis build Empty
PostSubject: Re: Mantis build   Mantis build EmptyTue Mar 27, 2012 7:41 pm
The hull is now finished and has been given a thin coat of sealer, a slot cut for the prop tube, the lolly stick stuck across the transom is just to make sure I get the prop tube in the right position.
Mantis build Dscf3611
Mantis build Dscf3612
Mantis build Empty
Mantis build
» Mantis sport hydro plans
» Next Build Tug
» Wee Nip Build
» HMS Hood
TheRcModelBoatForum.com :: Modelling Categories & Archived Build Logs :: Sport Boats-
