 Battery size
Waynekent0
Battery  size Empty
PostSubject: Battery size   Battery  size EmptySat Feb 24, 2024 5:51 pm
Hi
My boat uses a lipo 6.4v 12ah battery
Was just wondering if I could use a 6v instead
Any help appreciated
Many thanks
Wayne
Battery  size Empty
PostSubject: Re: Battery size   Battery  size EmptySun Feb 25, 2024 9:32 am
Should not be a problem, but Lipo's don't come on 6volt! If you mean an SLA or NiMh check your charger. The different battery types require different charging voltages.
JoJoElbe
Battery  size Empty
PostSubject: Re: Battery size   Battery  size EmptySun Feb 25, 2024 10:06 pm
Hi,
LiPo should have 7,4V 2S (3,7V per cell)
6,4V sounds more like LiFePO4  (in general safer than LiPo).
12Ah either means you drive for a long time? or fast?
6V would be lead (Pb)  or 5xNiMH ...
usually they are heavier than LiFePO4 (LiPo has even less weight)...
if all components worl with 6V it would just be a bit slower.
You see, many options to answer ...  if you want a 'safer' advice/hint you need to specify the question a bit more
Regards,
Joerg
http://modellwerft.spuelsaum.de/
Waynekent0
Battery  size Empty
PostSubject: Re: Battery size   Battery  size EmptyMon Feb 26, 2024 8:16 am
Yes sorry it is a 6.4v lifepo4 battery
JoJoElbe
Battery  size Empty
PostSubject: Re: Battery size   Battery  size EmptyMon Feb 26, 2024 5:39 pm
so then the question is how much power you need, do you need high currents (speed boat, jet)?
In that case the 6V either PB or NiMH should deliver these too. If not (normal to slow boat) it usually should work just be a bit slower.
ESC ususally should handle that difference and if you have more functions they mostly should also work with a little less power.
Why no LiFePO4 anymore??
J
Battery  size Empty
Battery size
» A couple of questions about SLA batteries
» Battery Charging
» Models by Design Puffer
» Deans Marine 1/24th Picket Boat
» Prop size and RPM selection
