| | Slot car racing | |
| Subject: Slot car racing Sat Apr 27, 2019 6:04 pm | |
| And now for something totally different big time!!!!! Me being me the big kid at heart has decided to build a slot car track ready for the Blackpool show,not wanting a double track like Scalectrix I want a single track to make a Rally stage,as rallying is one of my hobbies.My initial thoughts on this was to cut the Scaletrix track in Half thus giving me a single track but in my mind it wouldnt look all that good. Having attended a model show the other week I saw exactly what was in my mind,a single track layout,so 20 questions was asked to the owner and it is so so simple to make,simply router a slot an use copper tape for the contacts....More of this at a later stage. Today I decided to dig out 2 1/43 models I had bought a few years ago and haev nevedr got around to building,Both these are of my fav rally cars the Chevette Gp4 and the Chevette HSR. Where do I start,well as usual wash the shells dwon with Panel wipe got get rid of nay grease and rub then both down and de burr any flash off them with 400 Grit da disc,wash off again with Panel wipe and tack rag prior to primer then paint. GP4 58622725_334579960594546_8166227873451999232_n by David Jones, on Flickr 58590383_2298495217138648_7478667973742297088_n by David Jones, on Flickr Primed 58542814_1002623633281271_6320135416485773312_n by David Jones, on Flickr Painted 58444385_1921406501298928_376299453650305024_n by David Jones, on Flickr HSR In Primer 58602895_814958495570628_8998054732496896000_n by David Jones, on Flickr In Paint 58442665_444908936056778_6240764420855693312_n by David Jones, on Flickr 58614675_359808554654675_6995078755274194944_n by David Jones, on Flickr 59295571_667786830321184_7672587490913419264_n by David Jones, on Flickr Both of these were sprayed using Halfords aerosols as This is nice And thin so not to loose the fine details in the resin kit.I applied The silver within an hour of THE primer being sprayed...MMMM I can hear you all saying WHY on earth would you do this....Simple really nothing at all wrong with doing this as long as the primer has gone of flat with no visible imperfections,I do this all the time at work when doing smart repairs so with a model of this size I saw no reason at all not to use this system which is called simply Wet on Wet . If you want to see more different modeling techniques then you know what thread to follow.TBC Dave |
| | | Guest Guest
| Subject: Re: Slot car racing Sat Apr 27, 2019 9:19 pm | |
| those are nice models, look great, and something different...………
I like the concept and look forward to watching this...…………..can I have a go at Blackpool please...…...pretty please. |
| | | Guest Guest
| Subject: Re: Slot car racing Sun Apr 28, 2019 5:26 pm | |
| Today's job was to hunt down my old Scaletrix cars that are donkey years old....eventually found them litterally under my nose in a box underneath my worktop in my shed....lord knows how long they have been there as I Cant remember them even being there !!!!!!! Each one was stripped down oiled up and cleaned and washed with two of them needing a full respray,a Mini and a Tr7.The mini has been done and is drying...The Tr7 on the other hand needs new wheel arches and a full respray,this Tr is probably one of the only ones that actually stays on the track due to it being highly modified by having the chassis cut and lowered as the original Scaletrix Tr7 was never a good handling car. I will fully restore this to it's former glory as a Tr7 Rally car. The 2 Mini Clubmans are what you can but nowadays But the other 2 are the Old Train powered motors and are most definatly the better ones. 58460790_608288919647530_2627333693710008320_n by David Jones, on Flickr The Modified Tr7 looking rather sorry for itself with Faded paintwork needing Tlc and the Ford Rs200 4 wheel drive 58441116_886709235000882_7257622864763813888_n by David Jones, on Flickr If Anyone on here has any Scaletrix Rally cars they want to sell then please contact me please |
| | | Guest Guest
| Subject: Re: Slot car racing Mon Apr 29, 2019 1:09 pm | |
| gawd…...didn't know that sort of car existed...…………..last time I played with a scalextrix it had a BRG Vanwall and a shark nose RED Ferrari...……..showing my age now. |
| | | Guest Guest
| Subject: Re: Slot car racing Thu May 02, 2019 6:19 pm | |
| So we need a baseboard so some MDF and some 2x1 timber and screws were purchased form B&Q.After some initial drawing or doodling on the 6x2 sheet I decided it wasn't wide enough for what I wanted so the second sheet as cut in half thus giving me initially a 6x3....MMMM not long enough now so a 4x3 piece was also built giving me a total length of 10x3. Construction was an easy affair with the underside of the MDF being supported by a framework of 2x1. I suppose it could be called over engineered but when you are only using 9mm thick Mdf it needs serious strengthing and as this Track will be going to shows it will need to be strong. All the framework was glued and screwed using gorrilla glue wood glue and over 150 screws. Pics of the 2 track boards these will be set up outside the shed prior to the track being routered to provide the slot in the MDF allowing the cars to travel along it/ pics of the baseboards 59285358_290482475196418_7657332458567761920_n by David Jones, on Flickr 57267755_2375457906112451_5217286392962351104_n by David Jones, on Flickr 59455734_781769608884729_66068043100323840_n by David Jones, on Flickr I will be joining the 2 baseboards by using some steel pins as guides and then using bolts and good old fashioned wing bolts......the power across the joints will be by plug and socket but i will explain more at a later date |
| | | Guest Guest
| Subject: Re: Slot car racing Fri May 03, 2019 1:37 pm | |
| is it going to be a flattish run or a hill climb mate. |
| | | Guest Guest
| Subject: Re: Slot car racing Fri May 03, 2019 8:30 pm | |
| A bit of tarmac then transitioning into a forrestry section and then a Monte Carlo tarmac section but up a mountain all landscaped of course. Right then it was time to be brave with the router and wiggle woggle so to speak....an idea in my head and just set the router to 7mm depth and go for it......quite pleased with it now the hard work begins 59008877_422162155033067_5341722719492767744_n by David Jones, on Flickr The mountain section will be next but first I will have to get some more MDF and jig saw the road before I router it |
| | | Guest Guest
| Subject: Re: Slot car racing Fri May 03, 2019 9:18 pm | |
| this is very interesting.……..am looking forward to seeing more of this. |
| | | Guest Guest
| Subject: Re: Slot car racing Sun May 05, 2019 4:27 am | |
| Indeed Neil. Very fond memories of racing on a 10 lane commercial track within a bike ride from home 50 yrs ago. |
| | | Guest Guest
| Subject: Re: Slot car racing Sun May 05, 2019 7:18 pm | |
| Right then we now need a level base so I can work on the Track so a set of trestles were built and added on to my bench as a temp measure. 59321470_441149406448571_3485112531863732224_n by David Jones, on Flickr The Mountain section baseboard was added on to this 59448534_2284234841894437_5206715756892389376_n by David Jones, on Flickr So Now we needed to get some elevation on the track for the forestry section.....How do we do this...Quite easy really.I literally cut into the baseboard with a jig saw so sections were now loose so to speak....Similar to this one....I forgot to take a pic !!! so I've borrowed one.This will give me what I desire. Untitled by David Jones, on Flickr The cut sections were then physically lifted up and some timber was glued and screwed to the baseboard to hold them up 59889249_324835398206643_3027249471713968128_n by David Jones, on Flickr 59623603_377038859689154_8334433936818044928_n by David Jones, on Flickr
| | | Guest Guest
| Subject: Re: Slot car racing Sun May 05, 2019 7:32 pm | |
| 59573120_2619376804742517_4407863882924687360_n by David Jones, on Flickr As the baseboard needs painting before the copper tape is applied I started off with some Matt black tester pots that I had left over from a railway that I built,I also had some brown so that was applied to simulate mud...Yes I needs to be gone over with some darker brown to make it look more realistic,you will notice that the mud looks rough,All I did was to sprinkle some brown scenic material and over painted it to simulate deep mud....It doesn't look to bad in my eyes. I hope that when the cars run they will look as it they are shaking about due to the roughness of the track looking more lifelike. 59375484_847894522226810_5603007102189568000_n by David Jones, on Flickr 59374814_263437247789258_2817577921466597376_n by David Jones, on Flickr 59339644_351410122246253_3791726235625717760_n by David Jones, on Flickr In this pic I have tried to simulate the transition of mud to tarmac as when you come off mud to tar it carries 59360587_298532284415091_457037490126061568_n by David Jones, on Flickr A couple of car shots 59394779_2315771995327837_257476404562624512_n by David Jones, on Flickr 59492181_332359300803367_8765900127966593024_n by David Jones, on Flickr You will have probably noticed some blue material here and there this is closed cell Blue foam that will ne the basis for hills and will be shaped with a bread knife scalpel rasp file to get some contours and then overcoated with some filler. The foam has been stuck down using a hot glue gun,and when I ran out of glue sticks i reverted to good old fashioned Pva 59401426_338066863516677_1051238115219341312_n by David Jones, on Flickr 59623603_377038859689154_8334433936818044928_n by David Jones, on Flickr Dave |
| | | davidjt Forum Sponsor
| Subject: Re: Slot car racing Sun May 05, 2019 8:29 pm | |
| i like it very interesting ,cant wait to see how the electrics work david | |
| | | Guest Guest
| Subject: Re: Slot car racing Sun May 05, 2019 9:09 pm | |
| - davidjt wrote:
- i like it very interesting ,cant wait to see how the electrics work
david Electrics are a doddle the routered slot will have copper tape stuck down either side of them......Where the two pieces of basebord join the tape will simply go straight down and stuck underneath the baseboards where the power leads will simply be soldered on to same on the other one and a pair of connecting leads with a plug and socket to join them together simples Dave |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 06, 2019 7:39 pm | |
| Not a lot done today only some more Blue foam(THANKS NEIL)for the landscaping.I will obviously carve some of it to make is more realistic before I cover it with thinned down filler from B&Q,NO way on earth am I using car body filler HA HA. I have stuck the foam down with Pva and have used cocktail sticks ho hold down the subsequent layers,at the haripi I have used blue map pins to secure to the mdf 59664377_638283906595578_1910518435285041152_n by David Jones, on Flickr 59515663_283527902368203_4303730090140762112_n by David Jones, on Flickr 59493251_545226922674601_7643700945334829056_n by David Jones, on Flickr 59464616_479894839417917_5417208590786101248_n by David Jones, on Flickr 59410503_2992812944123848_1764044494119895040_n by David Jones, on Flickr |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 06, 2019 8:05 pm | |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 06, 2019 8:06 pm | |
| its looking very interesting though matey...….fascinated. bagsy first go at a show near you. |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 06, 2019 8:35 pm | |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 06, 2019 9:01 pm | |
| | | Guest Guest
| Subject: Re: Slot car racing Thu May 09, 2019 5:56 pm | |
| Wey hey real progress beginning to look much better today. Bought some filler from B&Q and added very little water to it to make it flow better into the nooks and crannies and it will look a bit better being smooth. 59723214_470665563677838_8788485703118880768_n by David Jones, on Flickr 59710980_444337943037283_3126903454694375424_n by David Jones, on Flickr 59717714_703711416752471_5884362305147240448_n by David Jones, on Flickr 59952722_452708465495621_6220297248127844352_n by David Jones, on Flickr 60002573_2260311967391217_6584941706725031936_n by David Jones, on Flickr 60095348_294298701508550_1988455298385313792_n by David Jones, on Flickr 60179241_833597083700049_1545666980739022848_n by David Jones, on Flickr 60360154_363388130948296_6175860983907483648_n by David Jones, on Flickr 60343289_2205114736233399_3445282843406630912_n by David Jones, on Flickr This is how it now looks ready for painting trees etc 59828610_361085584528846_1635595487019008000_n by David Jones, on Flickr Now the initial thought on this layout was to make a monte carlo type hill on it but like a woman ive changed my mind toatally !!!!! All the track is going to be painted black thus simulating a tarmac event,so the board that was destined to be a mountain is now going to have walls along it and it is now going to be a irish stage rally....BUT all is not lost with the Monte Carlo Mountain....another board will be made at a later stage to depict this and will simply connect to the excisting board!!!!!!...NEIL do NOT TELL KELLY she MIGHT JUST KILL ME . Now being an irish tarmac stage we needed a Yump...to the uninitiated it means a hump in the road that sees cars fly....now as I have allready found out the MDF didnt like being bent to that degree so a cunning plan was formed...simply cut a piece of old Scaletric track to a single strip and bend it slowly over my knee to give the hump effect ,now being a plastic track it will need lowering into the baseboard by using the router to cut and area where it will sink into,now here lies another problem MAYBEE but Stav has had his thinking cap on.....obviously I am using a copper tape to transfer the power to the cars so all I will do is to overlay the scaletric track with he copper tape The Yump 59860716_406537223501338_4394906078261805056_n by David Jones, on Flickr 60137791_417075312458630_7003798376403697664_n by David Jones, on Flickr This is what the track will look like ignore the plastic bridge as it is not being used now 59734841_800216097026890_5017226266558857216_n by David Jones, on Flickr Dave |
| | | Guest Guest
| | | | Guest Guest
| Subject: Re: Slot car racing Sun May 12, 2019 8:42 pm | |
| And the next thrilling instalment is...... I needed to have a megga shed sort out and move the track so I could walk around it and believe me it took all day on sat !!!!! YES NEIL I can see the floor. It was then Router time I needed to make the track on the other board and cut out a slot for the yump,and also join the boards underneath with some bolts. Today the weathering was started in earnest this was done very simply with some scatter material I had left over from a Railway project,I painted sections with some sample pots of emulsion and simply whilst it was wet the scatter was applied straight on to it,the material will stick to the wet paint and any gaps will not matter as it was painted with green and brown.The sections that have been painted green and brown will be recoted with some grey's to simulate rocks.The Track also was painted brown to simulate mud and gloss black to simulated not only wet tarmac but to make it slippy as well. 59991619_1360104997472214_2442527723478843392_n by David Jones, on Flickr 59978442_308722556708805_3711559111972749312_n by David Jones, on Flickr 60041156_2241773469420276_3623975662131347456_n by David Jones, on Flickr 60107782_346717832648118_6154039900048982016_n by David Jones, on Flickr 60101801_335243643825107_216503181062963200_n by David Jones, on Flickr 60273367_858896981153800_6221257108893990912_n (1) by David Jones, on Flickr 60344098_316125112388402_9012915040168181760_n by David Jones, on Flickr The yump or Jump 60042387_450319049054553_4611083262717067264_n by David Jones, on Flickr 60355039_2267531350178479_1194645359540830208_n by David Jones, on Flickr 60042383_418879758891764_8227043850154147840_n by David Jones, on Flickr |
| | | barriew Captain (moderator)
| Subject: Re: Slot car racing Mon May 13, 2019 6:19 am | |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 13, 2019 8:18 pm | |
| well, I must admit...…..….its certainly a lot tidier than my floor, in fact whole garage/workshop...……...and your track is looking great too. |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 13, 2019 8:24 pm | |
| been meaning to ask you for days...….am I alright to now mask all thee window openings from the outside by running masking tape right across them putting the stuff on the orange paint matey so I can rattlecan spray the insides black...……..or should I use a humbrol satin black and just mask up with maskol ……..don't want to ruin that beautiful orange you painted on.
cheers for the advice mate. |
| | | Guest Guest
| Subject: Re: Slot car racing Thu May 16, 2019 8:12 pm | |
| Had a day off today YEAH HA so it was shed time.......We seemed to have some growth appeared overnight in the form of Trees....the only 2 i had left over from the railway !! 60410654_328545834497700_1958852420981227520_n by David Jones, on Flickr So it was now time to put the copper tape to allow the cars to run,I had to make 2 slots in both the baseboards to allow the copper tape to go underneath so allow soldering of the power leads and the jumper leads to power the other board. 60337505_362548231039142_2214214353014489088_n by David Jones, on Flickr As the tape had to be really rollered down to make it stick and be as smooth as possible I really needed a wallpaper roller but I ain't got one so the best thing I had was some conveyer belt rollers that I was given so this was a hard nylon and would do the job 60289346_2396919047257907_283113755842183168_n by David Jones, on Flickr Pics in various state of being applied 60658178_2648708591868877_7756184090117668864_n by David Jones, on Flickr 60333552_421642645083506_5058937365439971328_n by David Jones, on Flickr 60226689_934949346675325_3650573552781885440_n by David Jones, on Flickr 60362521_2806603052688215_3729578441104687104_n by David Jones, on Flickr 60347695_659359841173959_4211873701890621440_n by David Jones, on Flickr 3 hours later I had finished so it was underneath with a soldering iron to solder all the cables to link the power up...By this time Dave was getting rather excited big time.....So out came the power pack and controller and it was time to test the track out....Well that's what I thought and you all know what thought means.....ARGHHHHHHHHHHHHHHHH DISASTER big time....The car set off down the straight and stopped and wouldn't go any further....Well you can imagine what was said and believe you Me it wasn't oH GOLLY GOSH.......I must admit I was cheesed off big time......AH Ha controller ....WRONG....ok power controller WRONG...ok it's the car not having being run for years WRONG...MMMm so what the heck was going on....not having my Meter at home as it was in tool box in work stumped me a bit.....till I thought about it....Having never done this type of thing before it baffled me for a while till SILLY ME realised I couldn't lay a full circuit in one go due to the actual thickness of the tape...if to much pressure was applied it simply Tore ,and me not thinking properly at the time didn't give it a second thought,and simply joined it up and carried on......trouble is ther is adhesive to stick the tape down,so you can guess why the cars didn't run.....I solder some of the joins up and wey hey they ran a bit further....so tomorrow's job is to not only bring the Multymeter home with me but also some solder nad go around soldering where we loose power bu testing the whole lot with the meter and hopefully I can then run the full lenght of the track Dave |
| Subject: Re: Slot car racing Fri May 17, 2019 7:43 am | |
| | | Guest Guest
| Subject: Re: Slot car racing Fri May 17, 2019 2:09 pm | |
| you are showing your wizardry now matey. |
| | | Guest Guest
| Subject: Re: Slot car racing Thu May 23, 2019 4:59 pm | |
| Well today I finally got the darned track to work.where I had put tape on top of tape due to it ripping whilst being laid it simply did not conduct electricity around the circuit so I had dead all over the place I eventually tracked them all down and simply soldered it all up wey hey we have it all up and running. I managed a best lap of 13.87 seconds nad low and Behold Catherine managed a full lap of 19.57 seconds not bad for a 5yr old,Well it was then Bethan's turn.....MMMMM I wont go into how well that DIDNT go !!!!!!!! lets put it this way the car managed to land on my workbench and daddy was not amused lord knows how she managed that one,bless she is only 3....Neil there is HOPE for you YET . Lots of work has been carried out today .....As soon as Flicker comes back on line Ill upload some pics and tell you all about it Dave |
| | | Guest Guest
| Subject: Re: Slot car racing Fri May 24, 2019 8:36 pm | |
| Well the first job of the Day was to remove the Hill as I didnt like it and was to high so a new one was made using a new glue gun I was given by the Kids superb piece of tricks from Liddle 61185392_296390494640095_8334621983371165696_n by David Jones, on Flickr I now needed to finish off the rock foundation 60801514_471021986775684_7762632850368626688_n by David Jones, on Flickr We now needed some hedges on the new board so I used the kids pool noodles and this was cut using the band saw 60897893_310117919908841_6621775178751803392_n by David Jones, on Flickr These will be covered up using plaster of paris then some scatter will be applied and hedge material as well A wall was needed from the start shed to the harpin I used some blue foam again cut with the bandsaw 60728259_2276573925916413_2904049318375718912_n by David Jones, on Flickr Some large rocks were also planted The Start shed where the timing will be located is work in progress 60922097_433042940855687_3501505833622044672_n by David Jones, on Flickr As the straight is fairly long and there is a chicane I needed some straw bales these were made form some scraps of the pool noodles and wrapped up using some black insulation tape 61146458_691737934578978_5638093085167583232_n by David Jones, on Flickr I also started making stage signage using a tooth pick and some scraps of plastic card 61136094_489908458217455_3090499865944260608_n by David Jones, on Flickr 60745843_436531170442486_7284230225817239552_n by David Jones, on Flickr |
| | | Guest Guest
| Subject: Re: Slot car racing Fri May 24, 2019 8:45 pm | |
| I used some old Scaletric Armco barrier for the bottom Hairpin which in time will be painted silvery grey 60782151_442783989613143_8706382859180441600_n by David Jones, on Flickr An overall view of what it looks like now 61002001_826992794366103_1150081805374717952_n by David Jones, on Flickr Dave |
| | | Guest Guest
| Subject: Re: Slot car racing Sat May 25, 2019 6:42 am | |
| | | Guest Guest
| Subject: Re: Slot car racing Mon May 27, 2019 9:57 pm | |
| beginning to look wild now mate...……...keep at it...…...shows a lot of different building techniques that can be incorporated into boat building, especially with the foam and fillers.
I'm enjoying it, and am sure others are too. |
| | | Guest Guest
| Subject: Re: Slot car racing Tue May 28, 2019 8:22 pm | |
| As I am off on hols it would have been so rude not to spend a day in the shed,right then I needed to apply some plaster of paris on all the new foam,the new mountain and hedges. All the track was masked up to protect the copper strip 61485728_665354693911194_1360363082064330752_n - Copy by David Jones, on Flickr 61421035_2261412207278178_9147464751960293376_n - Copy by David Jones, on Flickr 61564650_856835141344893_2519352842884481024_n by David Jones, on Flickr 61725202_655922594849534_4680252302269874176_n by David Jones, on Flickr 61523230_421888271941447_6335152271420030976_n by David Jones, on Flickr 61379516_831540007238987_1257103306535206912_n by David Jones, on Flickr 61258622_2143212175776640_8741566398045618176_n by David Jones, on Flickr All this was painted in a variety of colours grey brown and green this would act as a base for the scatter material 61132681_1852267721539877_2308076448042188800_n by David Jones, on Flickr 61187910_2220032291416820_3410319511809687552_n by David Jones, on Flickr The way I do this is simple,I do it using 2 methods either by applying the scatter straight on to hte wet paint or by applying Pva glue diluted with water sprayed on with an old household kitchen sprayer Applied straight onto wet paint 61921354_2160239337438478_1879966249849454592_n - Copy by David Jones, on Flickr My Grass mix of around 5 different scatters 61296612_1144438199074932_2853829459784499200_n - Copy by David Jones, on Flickr I scatter the mix using a kitchen seive 61209720_635720283566304_625468158806851584_n by David Jones, on Flickr 61222295_863760473986399_3317878432481673216_n by David Jones, on Flickr 61187910_2220032291416820_3410319511809687552_n by David Jones, on Flickr Second method is to spray the Pva glue on to the baseboard 61459053_2144019972319315_4730737808883318784_n - Copy by David Jones, on Flickr Then simply apply the scatter on to the wet Pva glue. I used this method to do the tops of the hedges and the rest of the scenerey. When I had finished all the grass material to make sure the scatter has glued down properly I simply wetted all the areas with Pva glue....this dries clear and is a fine mist and sets everything so it does not rub off |
| | | Guest Guest
| Subject: Re: Slot car racing Tue May 28, 2019 8:51 pm | |
| I am learning all the time matey...……….do you buy the green stuff, I e grass already chopped up n ready to spread.. |
| | | Guest Guest
| Subject: Re: Slot car racing Tue May 28, 2019 8:52 pm | |
| it is beginning to look amazing. |
| | | Guest Guest
| Subject: Re: Slot car racing Tue May 28, 2019 9:13 pm | |
| Neil you buy the different scatters in which colour you want https://www.ebay.co.uk/itm/Javis-OO-N-Gauge-Model-Railway-Wargames-Scenery-Scenic-Scatter-Grass-Ballast/201845805018?epid=1743178785&hash=item2efef28fda mg6AKze5fXyHHjQEDJn0Jkw&frcectupt=true I had some left over from a railway layout that I had in Blackpool a couple of years ago and I cant believe I had enough to do it all,a little goes along way,Ok I have got to buy some trees and those little buggars are expensive tbh...SSSSHHHHHH dont tell Kelly lol |
| | | Guest Guest
| Subject: Re: Slot car racing Tue May 28, 2019 9:26 pm | |
| One use of this scatter for model boats is the Dark grey or even the sand colour as non slip area's pvs on the deck apply scatter pva again and yes of course you can paint over it
| | | Guest Guest
| | | | Guest Guest
| Subject: Re: Slot car racing Wed May 29, 2019 9:32 pm | |
| Today I decided a couple of the corners weren't exactly right so to speak to many deslots (cars comming off),and far to many electrical problems so all the copper tape was removed and 2 corners were straightened out. Now how to repair the old slots and merge into the new one. First step was to re router a new route,having done this I needed to fill the old slot up and smooth into the new...I used some plastic card smeared with Vaseline to stop the filler sticking to it thus allowing a smooth passage for the cars 61834740_319326968979451_2466664228501585920_n by David Jones, on Flickr 61296617_1616830805141335_3130015038241243136_n by David Jones, on Flickr The entire slot was redone with fresh copper tape this time i managed only 3 soldered joints in it's entire length and boy oh boy what a difference I no have a smooth running track,whilst I was redoing the tape I also wired it up to allow a controller to be used both sides of the track with some plugs soldered in for ease of removal. As it is of tonight 61269793_2394397813952873_379781886148345856_n by David Jones, on Flickr |
| | | Guest Guest
| Subject: Re: Slot car racing Wed May 29, 2019 9:37 pm | |
| I like it...………..like it a lot...……... |
| | | Guest Guest
| Subject: Re: Slot car racing Thu May 30, 2019 9:35 pm | |
| Well the shed needed roofing and cladding so it was planking day 61662320_2186389834779016_2844226015989858304_n (1) by David Jones, on Flickr I cut some planks I had in stock roughly to length and then started planking using Mitre bond to fix them all in place 61539688_302952383920407_1403066795132190720_n by David Jones, on Flickr 61522276_2255839057841154_3973187285326757888_n by David Jones, on Flickr 61609920_620234571776519_1755429511278624768_n by David Jones, on Flickr 61769002_642934056168469_5839795190453239808_n by David Jones, on Flickr 61328911_351575719044149_9095929009878859776_n by David Jones, on Flickr I decided not to sand to much of the wood so it would look more realistic than a totally smooth finish so I simply stained it with some oak stain 61298178_644022859404323_2169532854751461376_n by David Jones, on Flickr 61295986_408420636666252_6306508348543991808_n by David Jones, on Flickr 61432368_704453510008596_2789863081621061632_n by David Jones, on Flickr 61540951_498083124062390_1087550062252261376_n by David Jones, on Flickr 61625152_300526767524117_7110434988364922880_n by David Jones, on Flickr Dave |
| | | Guest Guest
| Subject: Re: Slot car racing Sun Jun 02, 2019 11:41 am | |
| what timber did you use dave..looks like obeche, but probably totally wrong...…...looking good matey. |
| | | Guest Guest
| Subject: Re: Slot car racing Sun Jun 02, 2019 5:50 pm | |
| Honestly don't know TBH it was a whitish colour and was bought as job lot years ago...I know it cost me the vast sum of £2.50 for well over 50 lengths...think I bought it at Blackpool bring and buy or was it Coalville |
| | | Guest Guest
| Subject: Re: Slot car racing Sun Jun 02, 2019 9:50 pm | |
| - stavros wrote:
- Honestly don't know TBH it was a whitish colour and was bought as job lot years ago...I know it cost me the vast sum of £2.50 for well over 50 lengths...think I bought it at Blackpool bring and buy or was it Coalville
yeh…...…..just had a close up view of the grain pattern and I'm almost sure its obeche.. a simple test of it is when you sand it, it smells liker old fish boxes...….I love the stuff …..fantastic for sanding and carving. I use it for making my grp plugs, it carves and sands so easily. |
| | | Guest Guest
| Subject: Re: Slot car racing Mon Jul 01, 2019 11:15 pm | |
| how's the circuit coming along matey...…...have you done much lately. |
| | | Guest Guest
| Subject: Re: Slot car racing Tue Jul 02, 2019 9:21 am | |
| N Neil been to busy playing with it...sad I know,bought some cars off ebay and been bust restoring and servucung sime of my older cars....will be doing some more scenerty work when i come back from the Holiday from HELL up in Heysham !!!!!!
people come back glowing green from Heysham. lol. |
| | | Guest Guest
| Subject: Re: Slot car racing Mon Jul 22, 2019 9:40 pm | |
| It's Me again Boring you all to death with my ramblings....MMM do I care do I eck as like HA HA HA Been quiet on this for a while due to me having far to much fun,running cars and building them. It was time for do some more landscaping so as i needed to repaint the muddy section of the track with some brown and me being the cheapskate I am....must have some Yorkshire blood in me somewhere,decided a trip to our local Range wharehouse in search of some El cheapo paint and I came away having spent the vast sum of £1.25 for some Kids water based paint.......and YES Neil the girls have had the rest of it I painted the roads and then thought of course spread it on thick and then apply the scenic scatter using the tea strainers ....Happy days....not only did it stick to the paint succesfully and where the scatter was slightly thin it acted like brown earth underneath it . The Scenery is now around 85% finished only need to buy 200 odd trees and stick them in 67513442_702643010189231_7548969725020078080_n by David jones, on Flickr 67417871_2443925355840534_863887312440786944_n by David jones, on Flickr The brown has been dry brushed along the tarmac to simulate mud carried up the road off the cars 67234324_714726635653206_5313979498503340032_n by David jones, on Flickr 67162635_2348911805429053_6154626347768479744_n by David jones, on Flickr As my phone died terminally tonight I will take some pics of the cars with the camera and more of the track tomorrow |
| | | Guest Guest
| Subject: Re: Slot car racing Tue Jul 23, 2019 8:57 pm | |
| Some of the cars...All of these I have picked up on Ebay sub £20 and some of them now are worth in excess of £75ea!!!!!!....They all were in need of work ...paintwork motors etc Tr7 Scaletrix being converted to the works rally car...wide arches,faster motor and a heavily modified Chassis...Will be painted in full Works colours IMG_3671 by David jones, on Flickr A couple of Mini's that I owned previously...one is fitted with the old Train motor IMG_3670 by David jones, on Flickr A Escort Mk1 body shell in need of a lot of work !!!! IMG_3668 by David jones, on Flickr Escort Mk2 which I bought to get the running gear for another shell I had....this will eventually be painted in Colin McRae colours....red/black IMG_3667 by David jones, on Flickr A Vauxhall Magnum/Firenza Resin Bodied kit under construction IMG_3666 by David jones, on Flickr Mk1 mini IMG_3664 by David jones, on Flickr My Favorite car of all time the Vauxhall Chevette another resin Kit....body is loose on hte chassis as being worked on IMG_3663 by David jones, on Flickr IMG_3662 by David jones, on Flickr IMG_3661 by David jones, on Flickr Scaletrix Works Rs200 4x4 with the 4 wheel drive dissconeted...far more fun !!!! IMG_3660 by David jones, on Flickr Scaletrix Mini this was a limited edition only sold through M/S,just had to buy it as it was in Sponsored by a local childerns program and driven by one of the presenters IMG_3658 by David jones, on Flickr Ford Escort WRC rally car IMG_3657 by David jones, on Flickr A bit if a rarity this one even though there are hundreds on sale but this one is in a minority as it was released by Scaletrix but with the Name Porsche spelt incorrectly and is highly sought after by collectors....in this condition it is worth around £80 IMG_3656 by David jones, on Flickr The Jewel in the crown a Mk2 Escort very sought after model....these are changing hands on ebay anything form £60 upwards IMG_3655 by David jones, on Flickr IMG_3654 by David jones, on Flickr Dave |
| | | Guest Guest
| Subject: Re: Slot car racing Tue Jul 23, 2019 9:18 pm | |
| excellent stuff Dave.....……...looking forward to seeing this in the flesh in October. |
| | | Guest Guest
| Subject: Re: Slot car racing Tue Jul 23, 2019 10:25 pm | |
| | | Sponsored content
| Subject: Re: Slot car racing | |
| | | | Slot car racing | |
Similar topics | |
