Subject: Aeronaut Classic Sat Nov 19, 2016 9:52 pm
This is my first boat as you can see part way it to the build
Ian
Imcc Gunner
Subject: Re: Aeronaut Classic Sat Nov 19, 2016 10:03 pm
Trying the deck on to see how it fits. Would you add 1 piece of 4x2mm at the transom and trim the rear off the deck to suit. Or build it out with 2 to 3 pieces to match the deck?
ian
Subject: Re: Aeronaut Classic Sat Nov 19, 2016 11:41 pm
Ian your doing a ripper job on this first build congrats.
Ohh yeah and welcome to this friendly helpful forum.
Damien.
Subject: Re: Aeronaut Classic Sun Nov 20, 2016 8:42 am
Ditto the above
I see the essential cuppa is there
Posts : 2627 Join date : 2011-11-26 Age : 83 Location : Thaxted, Essex
Subject: Re: Aeronaut Classic Sun Nov 20, 2016 10:01 am
Regarding your deck - I think I would be inclined to trim it off at the transom. I did build one Aeronaut kit and did have an issue with some of the panels, which is a pity as they are otherwise excellent kits with very good timber and fittings.
Imcc Gunner
Subject: Re: Aeronaut Classic Mon Nov 21, 2016 6:31 pm
I will soon be buy sanding sealer and paint for the bottom off the hull. This I will applying with an airbrush. Filler and grain filler and varnish for the mahogany. Been searching the internet for tips and tricks and getting more confused. The question is what brand should I buy. I would like to go water based to help with cleaning. Help please Ian
Subject: Re: Aeronaut Classic Mon Nov 21, 2016 7:47 pm
looking mighty good.
I do like the wood that is used in these kits.....comes up lovely.
Imcc Gunner
Subject: Re: Aeronaut Classic Wed Nov 23, 2016 9:19 pm
The deck went on on Sunday, really happy how things are going . I've order rustins polyurethane varnish. Read somewhere that acrylic goes milky white after a while if you put it in water. I don't want that happening. Tried the seating out today and I've ordered a piece off gray leather for £6.00 from eBay to cover it. When that comes hopefully it's easy to fit. Cross fingers we will see.
Subject: Re: Aeronaut Classic Thu Nov 24, 2016 7:00 am
Looking Good!
Subject: Re: Aeronaut Classic Thu Nov 24, 2016 7:19 am
Certainly is looking good
Subject: Re: Aeronaut Classic Mon Nov 28, 2016 3:23 pm
Good easy boat to do, 'my blogs on here somewhere! Great build keep it up!
Imcc Gunner
Subject: Re: Aeronaut Classic Mon Nov 28, 2016 6:29 pm
Thanks Roadrunner. I've seen your posts and it's what inspired to buy this kit as my first build. I've used some of the mods you made to the boat, hope you don't mind. Ian
Imcc Gunner
Subject: Re: Aeronaut Classic Thu Dec 01, 2016 8:55 pm
Be working on the seating and surrounding area, sorry can someone tell me what you would call this, is it cabin? The seat is covered in leather. That's not easy to get it to look good . Had to go with this best I could do. Cut out white plastic sheet to fit the sides and covered with leather. These were a good fit and just clipped in. Soon be on varnish and paint
Ian
Imcc Gunner
Subject: Re: Aeronaut Classic Mon Dec 05, 2016 8:57 pm
Well took the plung and put the first coat of rustins grain filler.
Subject: Re: Aeronaut Classic Tue Dec 06, 2016 8:32 am
Ian
Perhaps you would call it a cockpit ?
Imcc Gunner
Subject: Re: Aeronaut Classic Sun Dec 11, 2016 8:00 pm
Varnish going on at last
Bit of a cheat this shot varnish still wet:lol!: Ian
Subject: Re: Aeronaut Classic Mon Dec 12, 2016 12:46 am
that is beautiful workmanship.......and a lovely looking craft.
Imcc Gunner
Subject: Re: Aeronaut Classic Sat Dec 31, 2016 5:24 pm
Had to wait for Santa to bring compressor and airbrush before I could spray the hull. Had to many threats of the wife " it will go back if you get it out of the box one more time" that I couldn't do it before. It didn't turn out to bad but I think I need a larger airbrush if doing anything larger. It will do for now.
At least now I can get it in the bath and test for leaks then it's the big day out
Ian
Imcc Gunner
Subject: Re: Aeronaut Classic Mon Jan 02, 2017 4:57 pm
Managed to get get down to a local sailing pond near me at bury for the first sailing to day and all went well. The sound at the end of the video is not aeronaut classic but a hovercraft also on a trial run out
All that's needed is add the last of the fitting and its finished Ian
Subject: Re: Aeronaut Classic Tue Jan 03, 2017 10:12 am
Subject: Re: Aeronaut Classic Wed Jan 04, 2017 2:07 pm
Imcc Gunner
Subject: Re: Aeronaut Classic Fri Jan 06, 2017 9:00 pm
The Managed to finish the Classic off this afternoon.
For my first boat I'm pretty happy with it Ian
Subject: Re: Aeronaut Classic Fri Jan 06, 2017 11:44 pm
A ripper model Ian.
Subject: Re: Aeronaut Classic Sat Jan 07, 2017 8:05 am
Very smart Ian. They make up into nice models do the Aeronaut kits.
