| Higgins P T hellcat | |
| Subject: Higgins P T hellcat Sun Nov 16, 2014 5:13 pm | |
| this is my first winter project from the june 2008 model boats free plan. the P.T. Hellcat. i wanted some thing i could do on the kitchen table as the garage is now to cold, this build i have used balsa and ply ,the skins are 1/16 th and ply is 2 mm the stem is 1/4 inch for strength. i sarted with cutting out frames then glueing together with P.V.A. wood glue url=https://servimg.com/view/18038893/204] | |
| Subject: Re: Higgins P T hellcat Mon Nov 17, 2014 6:24 pm | |
| the next stage was to cut out all frames in balsa and assemble together with P.V.A.. once this was done and dry I started planking with balsa, I am using 1/16 thick as I had this in stock. once I had fixed one layer I then fixed second to add strength as it should have been done with 1/8 thickness. when this has dryed it will need rubbing down. that will be tomorrow. once rubbed down I will use some tissue paper and coat with resin for more strength. than I will leave a few days to harden before I do any more, so that's it for now. more photos to follow later david | |
| Subject: Re: Higgins P T hellcat Mon Nov 17, 2014 6:46 pm | |
| this part is the start of fixing of the chine in balsa to second layer. url=https://servimg.com/view/18038893/208] this is it for a few days david | |
| Subject: Re: Higgins P T hellcat Mon Nov 17, 2014 10:33 pm | |
| Subject: Re: Higgins P T hellcat Mon Nov 17, 2014 10:50 pm | |
| It's coming along nicely David | |
| Subject: Re: Higgins P T hellcat Wed Nov 19, 2014 5:08 pm | |
| today I have coated all balsa out side, with fiberglass tissue and given 1 coat of resin. you cant tell on photo, i also fitted rudder which is ready made which I had, I am waiting for prop shaft to arrive from cornwall models this will be 10 inches long. tried all electrics to se where it would all go and servo all seems ok . | |
| Subject: Re: Higgins P T hellcat Wed Nov 19, 2014 10:57 pm | |
| Subject: Re: Higgins P T hellcat Thu Nov 20, 2014 8:55 am | |
| That should be strong and light David Barrie | |
| Subject: Re: Higgins P T hellcat Mon Nov 24, 2014 4:58 pm | |
| hi all, not been doing much lately but have fixed the rudder in place which I had already so used it up. that's it for now david | |
| Subject: Re: Higgins P T hellcat Tue Nov 25, 2014 3:57 pm | |
| today I have fitted the prop shaft which I bought from cornwall models, came very fast good supplyers . I have also put the prop on size 45mm x m4 which was in my stock gear, will try this first, the magazine build recommends it. then I fitted the servo which I also had I used some brass rod 1.5mm I find it works ok.you might be getting the idea I am using up all my stock, you are right. I have bought stuff from showa for builds like this but had no plans at time. this is the servo fitted next is the deck fittings david | |
| Subject: Re: Higgins P T hellcat Tue Nov 25, 2014 4:27 pm | |
| Getting there David I've been doing similar things myself | |
| Subject: Re: Higgins P T hellcat Tue Nov 25, 2014 5:23 pm | |
| Hi David - that's an interesting servo mount. Is it home made? I usually struggle to mount my servos.
| Subject: Re: Higgins P T hellcat Wed Nov 26, 2014 1:34 pm | |
| hi barrie, it is a simple box, made from ply glued together with super glue and clamps, you can make them thicker than mine but I find these work ok, fix in position by screws or two pack resin. I have done diagram for any new comers to building boats. I build all my boats with this method, and they can fit where you want them the open end is for servo cable to feed through to where you want. hope this helps others david | |
| Subject: Re: Higgins P T hellcat Wed Nov 26, 2014 1:40 pm | |
| Thanks David - a neat solution. Lately I have been using the miniature servos which save money & space and seem to have sufficient power for most models, including my fast ones.
| Subject: Re: Higgins P T hellcat Wed Nov 26, 2014 1:43 pm | |
| I to have been using the micro ones, just bought 4 for future builds.
david | |
| Subject: Re: Higgins P T hellcat Thu Nov 27, 2014 4:58 pm | |
| today I made the torpedo holders from plasticard. nothing else done today. david | |
| Subject: Re: Higgins P T hellcat Fri Nov 28, 2014 4:34 pm | |
| today I have spent making the deck cabin from square balsa,all stuck together with p.v.a. glue, then rubbed down to the desired shape. all the deck hatches were made from plasticard and resin to fix into place. u url=https://servimg.com/view/18038893/240] well that's it for today more tomorrow david | |
| Subject: Re: Higgins P T hellcat Fri Nov 28, 2014 8:13 pm | |
| Progress is progress David, some jobs just take longer than you think, my friend John says "a little each day gets the job done" and how true it is. | |
| Subject: Re: Higgins P T hellcat Sun Nov 30, 2014 4:15 pm | |
| Subject: Re: Higgins P T hellcat Sun Nov 30, 2014 5:32 pm | |
| Hi David, good to see you are near the painting stage Torpedo's look good, nice lathe, what is the working length I have been looking at lathes for various projects and this looks a neat little set up. | |
| Subject: Re: Higgins P T hellcat Sun Nov 30, 2014 7:23 pm | |
| David - I thought you said this was your Winter project. At this rate it will be finished before the snow comes Looking good Barrie | |
| Subject: Re: Higgins P T hellcat Mon Dec 01, 2014 9:23 am | |
| hi barrie, it is supposed to be a winter job cant stop , I keep saying I will have to move some of my boats on like you do at auction, I have far to many now don't no if I dare build any more. even the kids are worried what to do with them when I pass away, I say they can burn me at sea on them. but love building them to much . david | |
| Subject: Re: Higgins P T hellcat Mon Dec 01, 2014 9:33 am | |
| hi paul,
the torpedo tubes are just about as big as I could go, about 8 inches but I find it does what I want, I don't use it enough I was supposed to be making couplings but keep purchasing them instead. I wouldn't be with out it though.
david | |
| Subject: Re: Higgins P T hellcat Thu Dec 04, 2014 4:06 pm | |
| today I have made the gun turit frame work from 1,5mm copper wire soft soldered. and also made the radar frame, from plasticard and 1,5mm copper wire. david | |
| Subject: Re: Higgins P T hellcat Sat Dec 06, 2014 2:33 pm | |
| past few days I have made the machine guns and 1 cannon from plasticard and copper wire, that's the 1 cannon made now the machine guns well that's the guns sorted. still painting but have decided I don't like grey boats, they look very dull to me, I like to see some colour so I think I will avoid navel boats from now on. david | |
| Subject: Re: Higgins P T hellcat Sat Dec 06, 2014 2:53 pm | |
| - davidjt wrote:
- still painting but have decided I don't like grey boats, they look very dull to me, I like to see some colour so I think I will avoid navel boats from now on.
david I agree with you David. I've no interest at all in warships. There are three in my 'fleet', but they two are RAF boats, and third is an auxiliary, so none are grey The guns look very good - if you like that sort of thing Barrie | |
| Subject: Re: Higgins P T hellcat Sat Dec 06, 2014 5:13 pm | |
| I like the armoury David, especially the cannon | |
| Subject: Re: Higgins P T hellcat Wed Dec 10, 2014 2:38 pm | |
| well that is my build finished i cant say I am thrilled with it but there we are.i don't no what I will do next, as I have been told no more till I get rid of some of my fleet . I must say that this build didn't last long enough, I prefer to do plank on frame builds with more detail. there we are build complete waiting for sping now to sail it as it is now to cold and windy here. david | |
| Subject: Re: Higgins P T hellcat Wed Dec 10, 2014 3:07 pm | |
| Looking good David can't you sneak another in without the management knowing I don't have that problem, Barney doesn't mind what I get up to as long as he gets his daily walks he's a black Labrador | |
| Subject: Re: Higgins P T hellcat Wed Dec 10, 2014 5:56 pm | |
| Very nice David. I know the problem of builds that don't last long enough I don't think that is going to be a problem with this one. Trying to decipher Deans' contradictory instructions ensures a slow build Barrie | |
| Subject: Re: Higgins P T hellcat | |
